Front Prop shaft replacement
04' D II. 110K miles.
So I'm thinking I should replace the front prop shaft before it's too late and save my transmission. I've read tons of threads on here about it but wanted to do a quick re-cap to make sure I'm not missing anything. I'm going to order one from British Parts of Utah but since the weather here is a balmy 5 degrees, I wanted to yank the old one first, then wait for warmer weather to install the new one, which means I need to drive it without the propshaft. I've read to replace the 8 bolts as well and use a good socket as to not round off the bolts when pulling the old one.
I read that there is a nub on the CDL that needs turned after yanking the old one to engage the rear wheels. Where is the location of the nub? And is there anything I'm missing on replacing it. I also read to grease the new one during every oil change as well.
wow, if your old one is broken pull if not don't. if you are going to replace it you need two 9/16 wrenches. I would also recommend a 9/16 universal impact socket and with 6 inch extension and appropriate ratchet or impact wrench to remove the old one.
http://www.summitracing.com/parts/sx...FYNQ7AodUjYAcQ. .. example of impact universal socket
last on the list is some wire to bale up the drive shaft so it doesn't hit you in the head while removing/loosening old one.
So process is, jack up car safely, crewel under car wire shaft to frame for safety. loosen bolts toward front of engine first. The universal socket works great to get an angle on the bolts, you may want to wd40 these first. rotate the shaft to get at all bolts.
spin around and do the other side, put one hand on the shaft remove wire, 30 min job to remove tops 15 with an impact wrench. Take shaft in garage and inspect it are any of the joints loose. do opposite to install new one
So a local shop that rebuilds them is saying they lastest they've done is a 2001 Disco and he's not sure until he looks at the shaft if he can do it. My question is..are the 01's the same as the 04's? That will tell me that I should go ahead and pull it, and drive the shaft out to their shop.
The shafts should be the same from 01-04.
I use two 14mm wrenches and can get mine out in 10 minutes tops. I don't use wire to hold it up, I'm just careful. Raise one wheel off the ground to make it easy to spin the shaft, then lower the wheel to the ground as necessary it to lock the shaft and make it easier to loosen the nuts.
You don't have to mess with the 'nub' because your 04 has a CDL shifter. Just shift the CDL on after you pull the shaft and it should be fine. You'll have a new light on your dash warning you the CDL is engaged. People have driven around for months with no front shaft, so you should be fine til you get it rebuilt/replaced.
MAKE SURE THEY REPLACE THE CENTERING BALL. I'd triple check they they know you want it replaced. Many people have been screwed by shops not swapping the centering ball, and it's what makes the u-joints fail, so it's very important to change it.
It's good that you are doing this. My Disco's shaft failed for the previous owner and tore a hole in the floor (luckily the transmission survived unscathed). It had far less than 110k miles on the truck when it happened, so you are seriously in the danger zone with yours.
Could you send me the link for this? I have been searching their site and I can't find this exact propshaft... I feel incompetent.
