Front prop shaft transmission guard?
Yes the one people use spacers on when they lift a D2. All 3 of my D2’s have 3inch lifts & I removed those supports on all of them. Zero issues or difference in the D2’s. People tend to argue on them being on/off, and had I noticed a difference I’d have used spacers & kept them. However no change & I don’t have to worry about my shaft slapping into it or digging in (basically loosing any lift when you add a spacer).
No problem whatsoever.
Plus- you need movement on a 4x4 - the front shaft drops and moves with the articulation of the solid front axle. Locking it to one position would effectively handicap a rover
PLENTY of other 4x4's have a shaft loop, why? Why are they right in doing this and we arent?
The ONLY secure way to NEVER have the shaft hit the trans is to stop it from being able to go there.
Agree you could change, grease, zerk fitting your shaft to death, but in the end, it's the pmcs that saves your trans, but if everyone checked their shaft every couple months we would never see smashed trans.
But we do....
Are you saying the front drive shaft on a d2 does not move out of plane with the articulation of solid front axle? Just want to be clear.
I say this in reference to the cross member support beneath the front shaft being removed with a lift. I understand this is getting away from origin of post- I am just sharing my experience with this, not trying to force my opinion. Cheers
Negative. It doesn't move much at the transfer. Stop trying to justify your opinion.
But we do....
But we do....
