Front Wheel Sensor :help
Old 03-13-2012 | 10:17 PM
sayeedA's Avatar
Default Front Wheel Sensor :help
I replaced the right sensor after having that failed. Did the Shuttle valve fix (that seemed to work)
But I am still getting the following readings:
1.--Current Faults---->
Active Faults:
None:
Logged Faults:
044:Front Right sensor output low
064:Front Right sensor electric fail
Front Right Sensor Bad Output
114:Shuttle Valve Electric Failure
<-END Faults
..--Previous Faults--->
Active Faults:
Logged Faults:
None
<-END Faults
OK so decided to do some testing.
I am getting about 1100 ohms reading on the both side. Lifted the front, spun the wheels and both side looks like picking up signals similar readings.
I am convinced that I did the work right. Where is the problem????
Any fuse busted? 3 Amigos won't go away.
Will appreciate your take on this.
Thanks
Old 03-14-2012 | 07:00 AM
wilson96rr's Avatar
Is the hub leaking?
Old 03-14-2012 | 07:24 AM
The hub may be the cause for those faults.
Old 03-14-2012 | 09:20 AM
jbarr89's Avatar
did you hardwire the sensor to the control unit or back to the plug on the fender well?
KlamathMatt
04-17-2020 06:27 AM
Disco 2
08-13-2013 05:38 PM
aarongregor
02-15-2013 04:03 PM
sayeedA
12-07-2011 11:19 AM
twaszak
06-04-2011 08:49 AM
