fuel problem ?
fuel problem ?
have just got back from a 2000km trip on the way back had a problem with car starving for fuel when still had 1/4 of a tank discovery 1996 3.9 engine would stop could wait for 5 minutes start up and go for another 10 kms or so and the same thing would happen It did this 3 time at the same fuel reading on fuel gauge I finished the trip by keeping over 1/2 a tank of fuel and had no problems but as soon as it gets to 1/4 problem returns have I picked up bad fuel or is this a sign of fuel pump failure vehicle was serviced before leaving includeing new fuel filter. It looks easy enough to remove pump for inspection but wanted any suggestions or advice before I started PS no other problems or symptoms other yhan described above would appreciate any help THANKS MICK
RE: fuel problem ?
Well it is one of two things.
Most likely it is your fuel pump overheating and then quiting, once it cools it will work fine.
Your fuel pump is submerged in fuel, that keeps it cool, low fuel level = hot fuel pump.
The other is a bad fuel level sending unit, so you are actually out of fuel when the gauge still reads 1/4 tank.
Either way a new fuel pump is the only fix.
JumPeR04
04-07-2011 09:52 PM
40ranger
04-07-2008 12:20 AM
atikovi
04-07-2007 03:27 PM
