Fuel Temp Sensor
Old Jun 24, 2007 | 08:11 PM
willlane's Avatar
Default Fuel Temp Sensor
I took some pics of what I think is the fuel temp sensor. Is this correct? Is it under pressure? Can I just screw the new one in the same old hole?
Will
[IMG]local://upfiles/6749/9EE306B1376240258A018FD0F5A931BA.jpg[/IMG]
[IMG]local://upfiles/6749/A27BA5AFB7B647AFB6BEA42247E2F5FB.jpg[/IMG]
Old Jun 25, 2007 | 10:29 AM
Landzu's Avatar
Default RE: Fuel Temp Sensor
The fuel temp sensor is on the fuel rail.
Driver side.
Old Jun 25, 2007 | 10:31 AM
okdiscoguy's Avatar
I think you are looking at the coolant temp sensor. I think this is the fuel temp sensor. I know the fuel system stays pressurized, so I would run it down before you start. Pull the fuel pump relay, start the truck, and once it dies, it will be down. Turn off ignition and pull the negative lead on the battery.
Good Luck.
[IMG]local://upfiles/5440/52779820AC134683800C81A2F195E2EB.jpg[/IMG]
Old Jun 25, 2007 | 11:19 AM
willlane's Avatar
is there a way to test if it is bad (using a DMM? etc) before I spend 80 dollars on a new one?
Will
Old Jun 25, 2007 | 11:53 AM
Landzu's Avatar
I'm not sure how to test it.
But I know that it doesn't open into the fuel system, so
it can be taken off with out any worries.
Old Jun 25, 2007 | 07:08 PM
hunkslam's Avatar
5th Gear
hey, where you get the fuel temp sensor, no place here has one????? i need one bad
Old Jun 26, 2007 | 10:55 AM
98roverguy's Avatar
I have never heard of a fuel temperature sensor. Very interesting. I guess my formal education in automotive technology is expiring. Well. it's been 10 years almost. What would a computer system adjust based on fuel temperature?
Old Jun 26, 2007 | 10:57 AM
98roverguy's Avatar
ORIGINAL: okdiscoguy
Good Luck.
What a benefit you give to the forum with your pics. Thanks.
Old Jun 27, 2007 | 09:50 AM
okdiscoguy's Avatar
awwwwww, stop. you are making me blush.
I just got a new digital camera. That and Picasa make it really easy.
Old Sep 28, 2024 | 11:48 PM
landoverearth's Avatar
7th Gear
wondering where you bought your fuel temp sensor
