Full tune up - going for it
Old 01-20-2017 | 04:15 PM
RawFaith's Avatar
Originally Posted by Chrisw7562
The throttle body heater plate is an area that some choose to bypass due to a high amount of leaking from this area, sometimes after multiple fixes. Your's looks bad because that's where the coolant has been exposed to air (and leaking) for quite some time.
When I bought my 04 it leaked there and that was one of my first fixes. Mine didn't look quite that bad but almost. I bought a new heater plate with gasket from A/B for about $30 and used some permatex gasket spray on both sides of the gasket and tightened it up to spec and 1 year and 30,000 miles later it's still holding fine. See the link below for the new part & gasket, you can source it plenty of places.
You can also search around and find multiple lines of thought on whether to bypass the heater plate or not. I chose to fix it and leave it and I've not had issues. Other's it has vexed to no end.
Throttle Body Heater Plate Kit With Gasket (Includes MGM000010)
As a matter of fact, I ordered one " just incase"! will put it to use pronto.
Also, if you haven't done it already I highly recommend a complete rebuild of your cooling system. Your 02 is 15 years old and new hoses and a new radiator (along with an OEM 180 thermostat) are warranted. This will help keep the engine you are spending so much time on tuning up running healthy and cool for another 5 - 10 years..
That's the next project with the truck IF! everything works good with this "tune up". Really looking forward to some coolant upgrades, will actually go for the inline thermostat and possible 2 fans in front of the radiator, there is a ton of room there!
Originally Posted by chubbs878
coolant temps will make or break on these trucks
I know, geez, Im looking forward the inline mod!
  #42
Old 01-20-2017 | 04:18 PM
RawFaith's Avatar
ebay, $18
Attached Thumbnails Full tune up - going for it-img_9933.jpg   Full tune up - going for it-img_9936.jpg
  #43
Old 01-22-2017 | 07:03 PM
Chrisw7562's Avatar
Originally Posted by RawFaith
ebay, $18
Sweet pricing!
I was pro Atlantic British my first few months of ownership but quickly learned to troll eBay, Amazon and guys that support the forum like Lucky8 others. If you are slightly patient then it really isn't too expensive to own one of these. At least any more so than any other 13 to 18 year old car that would need all of the same kind of TLC that these do.
  #44
Old 01-22-2017 | 07:49 PM
Luckyjayb's Avatar
I use Atlantic British to get an idea of what I don't want to pay then check lucky8 and then over seas. I try to give my business to lucky8 but sometimes I can't pass up some of the deals I find in the U.K. Sucks I know but we are all trying to save what we can without making the other half too darn mad at "blowing money on a toy" as my wife says
  #45
Old 01-25-2017 | 11:58 AM
RawFaith's Avatar
Sorry for the delay on getting back here.
Got sick and without the intention of setting any records, I believe this will be the tune up that lasted weeks!
  #46
Old 01-25-2017 | 12:09 PM
RawFaith's Avatar
a ton of cleaning!
so far about 6 brake cleaners and 3 carburato let cleaners.
but is looking good!
time to put things back together
Attached Thumbnails Full tune up - going for it-img_9941.jpg   Full tune up - going for it-img_9942.jpg
  #47
Old 01-25-2017 | 12:10 PM
RawFaith's Avatar
old nasty spark plugs....
what do you think by their looks?
Attached Thumbnails Full tune up - going for it-img_9953.jpg   Full tune up - going for it-img_9951.jpg
  #48
Old 01-25-2017 | 12:34 PM
RawFaith's Avatar
Hmmmm
I don't like this... something doesn't look good.
doesn't the purge valve goes to a canister?
Attached Thumbnails Full tune up - going for it-img_9944.jpg   Full tune up - going for it-img_9947.jpg
  #49
Old 02-04-2017 | 06:37 PM
RawFaith's Avatar
Hmmmm
Can someone point me in the right direction? I don't believe this is how it goes
  #50
Old 02-04-2017 | 09:37 PM
number9's Avatar
Valve end should be inserted into hose going to the intake manifold and hose end heads down towards canister.
RawFaith (02-07-2017)
Quick Reply: Full tune up - going for it
