Gas cap issues
Gas cap issues
I tried searching but couldn't find this specific problem..
I've been getting a code for an evap leak and I'm certain it's the gas cap.
I've tried two different caps, and they won't thread more than half way in. The threads are too tight to get even close to making a seal.
I tried lubing things up but no dice.
Ideas?
Ideas?
My 2003 D2 had this code when I bought it, and it had the same issue. I bought the cheapest cap they had at autozone, and the problem was fixed for about 6 months. Then it wouldn't screw down completely again, just like the OE. I pretty much just lived with it until I sold it, but my next plan was going to be to buy a new OE part.
EDIT: that is one nice thing about the LR3. Instead of throwing a code, the display pops up with a message that says, "check fuel cap." Actually it DOES store a temp code, but at least it gives you the nice reminder before it sets a hard code and turns the light on.
This is actually a recall issue that was done at the dealerships on the unsold stock, but was not performed on already sold stock. They either replaced the filler neck, or the cap, I don't remember. Mine does the same during warmer weather. I'm going to try steel wool on both sides as per a recommendation I read on this thread. But, remember to not let any sand paper or steel wool down the pipe.
If I'm remembering correctly, I believe they replaced the cap with a smaller circumference one.
