Gasoline question
Gasoline question
As gas prices keep going up here in Texas, I was wondering about using a different grade of gas in my disco?
has anyone done this? if I go to a lower grade of gas is there an additive?
or should I just stay with premium gas ???
Thanks
Ralph
www.ralphduke.com
Thanks
Ralph
www.ralphduke.com
gotta stick with the pricey stuff.. I know it hurts. I am suppose to head to Charlotte NC in a week for work was going to drive but am now looking at flights even with baggage charges for camera gear it may be cheaper than the gas plus wear and tear.... prices here in Philly are between 3.65-3.71/gal.
The truck requires 91. I'm not sure by you, but by me you could only get 93. If you are really looking to stretch your dollars, it would be fine to fill with premium 93, then refill with regular 87 before the 1/2 mark... or about 10 gallons. That would equal out to making your own 91. You could also just do half and half at the pump. Premium has more detergents, but if you run a cleaner every so often you will be fine.
