Gear shifting problem
Old 03-23-2021 | 10:03 AM
zero-one's Avatar
6th Gear
Default Gear shifting problem
Hi
I've Disco II V8 with A/T ..I put the gear on D and drive it jumps directly from 1st to 4th gear and did not kickdown to 3th or 2th until stop and switch engine of..at the same time M & S lamps flashing..No fault codes in transmission module..But in live data when I put the gear in D for example it shows on P but in the cluster and indication diodes shows it correct position .other thing in live data show that transfer range in low ...
Any help please
thanks
Old 03-23-2021 | 10:50 AM
mollusc's Avatar
If you are in low range and the Sport button is pressed, you're in manual shift mode so D corresponds to 4th gear. Shift the small lever back into Hi range.
The M&S lights flashing is often caused by low battery voltage. Make sure your battery is charged and that the battery terminals are clean and tight.
zero-one (03-23-2021)
Old 03-23-2021 | 11:47 AM
zero-one's Avatar
6th Gear
It is in low range,, I tried pushing the mode button many times but nothing changed,,,
The TCU power is 11.6v as the scan tool reading.
Old 03-23-2021 | 11:49 AM
mollusc's Avatar
Take it out of low range by using the small shift lever.
That voltage is very low. It should be up around 14v when the engine is running.
Old 03-23-2021 | 04:37 PM
Richard Gallant's Avatar
@zero-one very low voltage I get 12.6-14 at the ODB port but a steady 14.1 -14.0 at the battery. Check your battery with engine off for about a hour then check it running it should show high 13-14.
I have a problem that needs to be sorted in better weather as far as the ODB reading goes
Old 03-27-2021 | 02:39 PM
zero-one's Avatar
6th Gear
Update: Now TCM voltage is 13.5v... M/S deactivated ... But still the same symptoms.. Still gearshift position not matched between the actual position and the position read from TCM but matched with the position in the dashboard...
Gear switch : invalid
Kickdown:inactive
Old 03-27-2021 | 06:33 PM
XRAD's Avatar
" live data when I put the gear in D for example it shows on P but in the cluster...." not good...start with below...
check the wiring/connector at trans xyz selector connector? have a spare xyz switch to try? check trans selector position at trans?
Old 03-27-2021 | 11:45 PM
zero-one's Avatar
6th Gear
But it gives the correct position in the dashboard
Old 03-28-2021 | 08:37 AM
XRAD's Avatar
so to be clear, when in 'D' on the dash cluster, then you have the 1st to 4th skip? AND the trans is NOT in 'D'....
assuming the cabin shifter is OK, and trans is OK (which is a simple mechanism so unlikely to be the issue), and the XYZ switch is OK, then maybe the selector cable has slipped on the trans selector arm? have to eliminate one at a time...
Old 03-28-2021 | 08:58 AM
zero-one's Avatar
6th Gear
D on dash cluster and on transmission,, but not on D when get live data from TCM by scan tool.
Yes it jumps from 1th (with kick sound) to 4th and fix on it no kickdown to 3th or 2nd...
Do you think the TCM malfunction?
Quick Reply: Gear shifting problem
