General question on differentials...
I know there are other places to ask this question, but you guys are the most knowledgeable I have ever come across. So I only feel comfortable asking here.
I just changed the rear diff fluid in my XJ. It has almost 185K on the clock. I am not sure when it was changed last (I have had the truck a shade over a year) and I figured it was about due. Plus, working on the Rover has given me the confidence to tackle other things on other vehicles.
Anyway, the diff fluid was dark. Smelled terrible, as gear oil always does. When I got it into the sun, it looked sort of like the metallic chip paint that you might see on a black or blue vehicle. There were no hunks of metal, and none of the sparkles were big enough for me to focus on, the fluid was just glittery. As I was pouring it into a jug, I noticed that I could see through the stream, so it wasn't completely opaque.
How does this sound? Is it normal for old diff fluid to look sparkly? Otherwise, the gears look good, and there wasn't any crap laying in the bottom of the housing.
Not a good sign, you most likely have some bearing wear going on and having been a service manager for Jeep for years, I know their failure rate.
I would suggest you swith to a 75W/140 gear oil and if you don't have one install a magnetic drain plug to catch some of that floating metal.
I already picked up the 75w-90 gear oil so I'll walk it back to oreilly's and exchange it.
yeah the "sparkly bits" are tiny metal shavings from something inside your diff... means you have some wear goin on that you may not notice till later... if you find any small chunks of metal in there do not think "i wonder how this ended up in there?" because it did not magiacally "get in there" it was always in there, just at some point attached to something else in there and now the part that used to be your gears in metal flake in your oil painting...
topgear
06-18-2005 12:29 AM
