getting a D2 ready for towing duty
Old Jun 12, 2012 | 05:50 PM
  #21
nychaze's Avatar
I have a Boat that I tow around quite often, brought it from NY to CO about a year ago. 1800 miles, 2 days of over 12 hrs of non-stop traveling at 75-80MPH, boat and trailer weight about 4500 with no trailer brakes, no problems and never got hot.
I towed it about a month ago with my 33 on (off-road tires, typically keep my stock 18s on but just had to get the boat) WOW was that fun...its fine on flat land but soon as i started on the slightest hill i could barely maintain 55 and would never tow it again with the 33s.
Where you are going to be towing is a big factor. I would never take the boat and trailer into the mountains without brakes on the trailer or in general since it would be hell but if I lived anywhere in the plain states i would just tow with the 33s on since everything is flat...
Does anyone know if there is a port on the side of the tranny you can plug into to get tranny temp? Could you remove the current temp sensor and replace it with an actual dial gauge or does that communicate with the ECU for tranny control?
Old Jun 12, 2012 | 08:36 PM
  #22
No the trans temp sensor does not talk to the trans computer.
Old Jun 13, 2012 | 06:40 AM
  #23
drowssap's Avatar
nychaze's
you have 33's on there and have not changed your gearing? small wonder there is no low end toqure. you should have gone to 411 gearing with the 33's, to regain some of the toqure.
Old Jun 13, 2012 | 09:05 AM
  #24
nychaze's Avatar
Originally Posted by drowssap
nychaze's
Its on this list...along with a ton of other things...
I can get away with it since I only put the 33s on for off-roading (Treadwright 285/75R16 BACKBONE) and in Low range gearing isn't an issue on the trail. I have my 18s with road tires that i switch to for everyday driving...saves the tread on the trail tires and dont have to deal with the humming of the tire
What do you guys think about ditching the current temp sensor that only tells you when things are out of control and replacing with a dial gauge? Where is the sensor located?
Blakesrover
Feb 20, 2013 10:31 PM
calebbo
Nov 9, 2011 11:31 AM
Aj6543
Sep 21, 2009 11:17 AM
Camdisco24
Feb 23, 2008 06:41 PM
shendren
Defender
Jan 22, 2008 01:22 PM
