Grade of Nylon Threadlocking nut(s)
Hence the question remains, what is the grade of the OEM bolts, or the nylon threadlocking nuts.
Thanks.
This statement is also the definition of achieving proper torque:
"Nuts are designed to yield (deform) around the threads of the bolt, thus distributing the load evenly among the nut threads."
Just as a guess, I think hte nuts in this application are the same grade as the bolts, the need to withstand the push/pull forces of the shaft while the bolts need to withstand the rotational sheer force.
I recently tried to find out the same answer because I'm replacing my driveshaft with a TW, so I called AB and talked with brian(?), I wanted to simply order new ones (which they have on hand, he said) he first stated I can not rebuild the driveshaft and have to order a new one, I told him I was replacing the shaft (not theirs) then he seemed to be pissed, then not only did he not answer my question he told me to go to the hardware store and buy them simple as that and pretty much just cut me off.
OK, yeah, I forgot about the whole metric grading system being different. I personally would only use grade 8, or in this case, being a British vehicle, the metric equivalent. I haven't tried it, but you might be able to see the bolt head by climbing under the truck and looking. If it is metric, the grade stamp is a number. Either 8.8 or 10.9. If it's SAE, the grade is marked with either 3 or 6 hash marks pointing in from the edge of the bolt head. 3 is Grade 5, 6 is Grade 8. http://en.wikipedia.org/wiki/Bolted_...Property_class
