Hard to start... only sometimes. Runs great
Old 03-11-2018 | 09:19 PM
sickws6's Avatar
Default Hard to start... only sometimes. Runs great
So I recently did the following:
Plugs wires
Cps
Coils
02 sensors
Car runs great and has been a few weeks since completed the above items.
Last week it would start, had to Crank and Crank and Crank. Finally it fired and ran perfectly fine
I didn't think much of it. Well today same thing happened. Cranked like 40 times. Finally fired once I shifted into drive then back into park. Could be a coincidence.
Any suggestions on where to start troubleshooting?
Thanks!
Old 03-11-2018 | 09:30 PM
Best4x4's Avatar
Sounds like low fuel pressure at the fuel rail upon start up. Could be a weak fuel pump or an injector leaking down when the engine is off.
Old 03-11-2018 | 09:37 PM
sickws6's Avatar
I will check fuel pressure tomorrow, is there a test port? How to diagnose your suggested issues?
Old 03-12-2018 | 08:57 AM
Best4x4's Avatar
The test port is back by the coil packs.
Old 03-12-2018 | 03:20 PM
sickws6's Avatar
Rave manual doesn't specify much about this?
Old 03-16-2018 | 09:09 AM
sickws6's Avatar
You think it could be related to the new Crank sensor I put in?
Old 03-16-2018 | 10:40 AM
number9's Avatar
How long did it sit between starts? Since last week?
Old 03-16-2018 | 10:41 AM
sickws6's Avatar
About 10 days or so.
Old 03-16-2018 | 11:49 AM
number9's Avatar
Would think that lends more credence to a weak pump or injector issues.
Old 03-16-2018 | 11:56 AM
sickws6's Avatar
If I had a fuel issues I would suspect poor running though wouldn't I?
Quick Reply: Hard to start... only sometimes. Runs great
