Hard to start... only sometimes. Runs great
Old 03-16-2018 | 01:59 PM
number9's Avatar
Has it been hard to start like this the past after sitting for 10 days?
Maybe you need to start every day and drive it to see if you see what it's really doing and note any other symptoms. If it works good on a daily basis why sweat it?
Old 03-16-2018 | 05:51 PM
sickws6's Avatar
No I drive it about every other day. It happened about 12 days ago then 2 days ago. That's it.
Old 05-21-2018 | 05:52 PM
sickws6's Avatar
Crap. So replaced fuel pump. No issues for a week. Then today no start. I'm lost
Old 05-21-2018 | 08:04 PM
sickws6's Avatar
Maybe I'll replace the Crank sensor again this time not cheating out.
Old 05-21-2018 | 08:28 PM
CollieRover's Avatar
Cheating out?
Old 05-21-2018 | 08:51 PM
sickws6's Avatar
Originally Posted by CollieRover
Cheating out?
Cheaping out
Old 05-21-2018 | 08:56 PM
Cheaping out
ah. I put in a standard motor products in January. Haven’t had an issue.
Old 05-22-2018 | 07:38 AM
sickws6's Avatar
I'm dreading dealing with that clip again on the Crank sensor.
Old 09-27-2019 | 07:30 AM
sickws6's Avatar
So I ended up changing out the crank sensor several months ago and have not had any issues until couple days ago.
Now similar issues with not starting HOWEVER as weird as this may seem , this time I discovered hitting the gas pedal while cranking gets it to fire. I understand this technique usually doesn't apply to fuel injection cars but it works. What could this be? Leaking/dirty fuel injectors? I did witness a rich fuel smell upon start-up. will fuel injection clean be worth while with the canister style element cleaning system?
Old 09-27-2019 | 08:20 AM
You think it could be related to the new Crank sensor I put in?
Bad crank sensor won’t crank at all.
Quick Reply: Hard to start... only sometimes. Runs great
