Hard Start, SRS light, Dead Battery. All Intermittent. Bad Alternator Ground?
Old 07-26-2018 | 06:51 PM
akrover90's Avatar
Default Hard Start, SRS light, Dead Battery. All Intermittent. Update: Now just dead.
About two weeks ago I noticed the truck took a second or two longer to start. That has slowly gotten worse. Now it'll 50% not start on first crank, but will start on second if needed. Once started, it drives great. I also randomly have an intermittent SRS light for low voltage. It comes sporadically and usually disappears with the next start. It may not come back for a week. I have had the battery tested and it is good. I had a GROM RVRA1 plugged into the CD changer port of the radio running an Aukey BR-C8 bluetooth setup with a 1/8 stereo mini cable. I figured that was causing the drain, so yesterday I disconnected it, charged the battery and everything was great. Then, 20 hours the hard start returned. two hours later the SRS light returned. I went to recheck everything, pulled the battery to test / charge it again. As I was checking the grounds, for the first time, I did more than just eyeball the alternator ground and it just came right out with the slightest tug! I've never actually looked at the ground connection before to know what 'normal' is, but I assume the post is broken off? I'd guess this is the cause of my problems? Do I need a new alternator? Can this somehow be fixed? Any help would be greatly appreciated.
Old 07-26-2018 | 07:22 PM
User's Avatar
Yeah.. that's supposed to stay in the alternator..
Old 07-27-2018 | 02:52 AM
The Deputy's Avatar
I'm surprised your low voltage light wasn't coming on, too. But, yes...you'll probably need a new or rebuilt alternator. That stud was most-likely soldered in place, not sure if you could resolder after removing plastic cover/regulator housing...but worth checking first.
Brian.
Old 07-27-2018 | 03:05 PM
akrover90's Avatar
Brian.
Yup, no low voltage light. Weird.
I just ordered a 150A p38 one to replace this. I want to get this fixed by next week before a camping trip and have my finger's crossed this was the source of all the aforementioned problems.
Old 07-27-2018 | 03:55 PM
The Deputy's Avatar
Take plenty of pictures of your camping trip, especially with the rover involved. We need to see more of this stuff, to inspire the masses.
​​​​​​​ Brian.
Old 07-31-2018 | 11:02 AM
akrover90's Avatar
Okay, I got the alternator in yesterday (because Will Tillery is the man) and it seems to have solved all my weird electrical problems (and my CD changer works again for the first time in 18 months), but I’m still getting the hard start. It starts fine cold, it starts fine hot, where I seem to be running into problems is when it is warm. So if I try to start it after it has cooled down for :30 > 1.5hr, then it takes two cranks to start it.
confirmed good battery, good alternator, solid grounds, and Crank Position Sensor was replaced in the last two years. I guess next step is to test the starter? That looks like an interesting job if I have to replace it. Any other thoughts?
Old 08-01-2018 | 12:43 AM
User's Avatar
When you say hard start, do you mean it is not turning over? Not turning over quickly, etc..
Old 08-01-2018 | 06:26 AM
akrover90's Avatar
When the problem shows up it either doesn’t turn over quickly, or it won’t turn over at all the first time, then will turn over on second turn of the key. Though last night it took a long time to turn over on first crank but then right as I was giving up it did, then stalled. On second crank if fired right up.
Also, my SRS light came back. Then went away again.
Old 08-01-2018 | 11:06 AM
stxscott's Avatar
Double check your ground cable from battery to engine.
My ground cable that connected to the alternator mount was only very slightly corroded and I had exactly the same symptoms. I replaced starter and still had issues so I ended up jump starting, but the starter was grounding via the hand brake cable = smoke. Not pretty.
Old 08-01-2018 | 12:10 PM
akrover90's Avatar
Good point, I’ll do that again later.
I put the Ultraguage voltage on and it is low now. I had been using the iphone version, but switched to the old fashioned one so my wife could see engine temps and doesn’t have the voltage on the main screen. It was always 14 or a tad over before, now I’m getting anywhere from 13.4 to 13.8 while driving.
Quick Reply: Hard Start, SRS light, Dead Battery. All Intermittent. Bad Alternator Ground?
