Has anyone removed their stock running boards?
I would like to take mine off and was wondering if I could buy two mud flaps for the front and bolt them right on?
Is there any extra trim pieces missing I would have to buy?
Thanks in advance.
I did a search but didn't see where anyone had put mudflaps back on.
Thanks in advance.
Man, I have no idea, just assumed they were stock.
If they have front mudflaps built in, that follow the contours of the front wheel arches, they probably are stock (factory option or add-on) The factory boards are attached to the frame with 8" or so outriggers. (I had to go check mine which are on the roof of my RX-7 in the garage still.)
Just make sure you unbolt all the mounting hardware, the *** who removed mine just removed the boards. The first couple of times i rolled under the truck i got a steel bracket in the middle of my forehead.
So, did you put mudflaps back on?
