Having a hard time removing air from coolant system
You must have coolant in the heater core hoses. A simple test is remove both hoses and pour distilled water in one hose, you should get water out the other end. Try both ways to be sure you have no blockage or air trapped in there. If the water flows easily both ways then reconnect the hoses and try again. If you keep getting air in the system then you have a leak somewhere.
echomike
03-13-2011 07:23 PM
Snafu / Disco Fries
02-01-2011 02:10 PM
