HELP! replacing my hoses and good spray nozzels for washer fluid. Need to know how to thread hoses and shouldn't the spray nozzles come with a rubber gasket to avoid leaks/corrosion? Do the hoses go on top of hood cover or behind?? Already broke the main hose L clip on the front driver side Ugh. I just had to replace this b4 snow on Friday! Eek
Lessons learned - ask LR Forum B4 starting the work on my D2. The heat gun is most excellent. Also, Yes duct tape does the job anytime..Thanks for the most excellent advise
I broke the same one. I used a vacuum hose elbow the same size as the hose ID to connect the 2 pieces of hose. The same part is gonna break again at some point so why bother replacing it with the same thing? Stupid design if you ask me, and garbage lowest bidder plastic all over the truck in general.
