Head Gasket and junk
Well, I just drove across the country, and I noticed that there was a LOT of crap building up on my engine. I'm not a mechanic by any stretch of the imagination, and my mechanic says that it's getting a complete rebuild from the bottom up. Here's some pics to show the work.
![](http://i994.photobucket.com/albums/af70/thebelly925/IMAG0018-1.jpg)
![](http://i994.photobucket.com/albums/af70/thebelly925/IMAG0019.jpg)
and a close up of the sludge
![](http://i994.photobucket.com/albums/af70/thebelly925/IMAG0021.jpg)
ETA: Pikes Peak Rovers in Colorado Springs is the shop I'm using.
Time to spend some money at the nearest hot-water do-it-yourself car wash buddy. Take a roll (or 3) of quarters, a couple of cans of engine degreaser, and some saran wrap (to put over the fuse box and electronic parts under the hood) and give your baby a good once over. While you are there you might as well go ahead and wash the under body too. Not only does it show your rover that you care but it allows you to see where this gunk is coming from and spot any potential leaks early.
Enjoy! -this is never a fun task in feburary...
That was what it looked like this afternoon. I'll post up some pictures of what it looks like after it gets completed. Like I said, I'm not a trained mechanic. I'm lucky to have helpful people that I can trust on my side, or rather on the side of my Disco.
A couple of months ago I took it to a dealership on the east coast, and the advice they gave me (come to find out) was contrary to ...... well, if I knew then what I know now, I wouldn't have driven it across the country.
**UPDATE**
Here's the parts list from just the head gasket job:
Head gaskets kit
intake gasket
intake end seal
valve cover gasket
head bolts, short
head bolts, long
exhaust manifold gasket
valve cover screws, short
valve cover screws, long
Oil Filter
10W30 Oil
Bosch Drain plug washer
coolant
exhaust nuts
exhaust studs
Bosch Spark Plugs
Sublet Valve Job: I saw the little invoice for this, and it went to McCabe Motorsports. I've never heard of them, but the valves look great.
The other thing that is getting done tonight is that the Steering Gear box is getting rebuilt. I don't know much about this, but the rebuild is less expensive than a new one, and the mechanic has a warranty in writing.
The mechanic is Pikes Peak Rovers in C Springs, CO. I'll keep saying it, but I don't know much about mechanic-ing, but Wil (from PPRovers) has made me feel extremely comfortable about the services he's providing, and the Stealership here actually sent me to him. (that also says a lot about the place)...
Here's a 'midway' pic of the rebuild.... yes it got all cleaned up.....
Head gaskets kit
intake gasket
intake end seal
valve cover gasket
head bolts, short
head bolts, long
Oil Filter
10W30 Oil
coolant
exhaust nuts
exhaust studs
Bosch Spark Plugs
![](http://i994.photobucket.com/albums/af70/thebelly925/IMAG0023.jpg)
