head gaskets, valve question
Ok, im home and have all the info from the codes. Heres the codes it was originally throwing. PO134 PO171 PO1171 PO455 P1300 PO308 PO305 PO307 P1129. I have the heads off spark plugs in cylinders 2,3,5,and 8 were black and ive only had the car started once since they were installed. Im going to take the heads to a machine shop, have them cleaned up and vave job done. What do i have to check the cams? I just replaced oil and water pump and dont want to pull them back off if not necessary. One thing i noticed is the 4 plugs that are black all go to the RH coil. I guess i could have got a bad coil? Thanks for all the help.
RROJ
03-26-2011 02:37 PM
