headliner
i noticed the other day that i have a few spots in my headliner where it is starting to droop down. i read in some post a while ago that the best thing is to have the whole thing replaced but i want a second opinion since the areas that i have are fairly small ( about the size of a baseball ). any suggestions or ideas ?
What kind of glue should I use..I have a really small area thats loose, I was going to use the gluing method.
Thnaks
Ralph
www.ralphduke.com
Thnaks
Ralph
www.ralphduke.com
Can you get to the back of it? If so, peel it back and get some adhesive spray. Made by 3M I think it is 70 something??? If it is in the middle, you will have to use a syringe to shoot it in. This still may not work.
The reason it is sagging is the foam backing on the mateial is shot, so you will still be gluing to crappy foam....
I did mine ( no sunroofs) in just under 3 hours. I had never done one before...
ORIGINAL: okdiscoguy
If itsnot a hugeareayou can use those tiny wall pins to hold it in place, they kind of look like needles with tiny heads.Ipushed two in 2 years ago (in two different spots)and its holding it perfectly still to this day. Because to be honest with you, in not willing to put in $250 bucks to fix something that can be held up by .$02 pins. No one notices them and they wont fall out.
Obviously this is a temp. fix to something that will eventually get worse, but heck, its money in my pocket. For now.
Don't inject glue. I've done this and I just kicked myself when I saw what I've done.
It left dark splotches of glue residue on the headliner, the glue should be clear when it dries up but instead it left dark dots (maybe it attracted dirt or it darkened the color of the liner) It also feels bumpy, globs of hardened glue in the foam.
The best way is to peel of the head liner (the most difficult part) and spray 3M adhesive spray. HTH
