heated windshield plug/wire
Old 11-19-2022, 03:40 PM
Trailmix's Avatar
Default heated windshield plug/wire
Just had windshield replaced on my 2004.The driver's side works, but passenger side does not work. Both plugs get power, but I notice the wire colors don't match up on the passenger side. Purple is going to black. Is that the problem? Can somebody check thier truck for me?
Old 11-19-2022, 05:18 PM
longtallsally's Avatar
Ooh, I can’t recall how it was on my ‘00, but I’m going to put a heated windshield in my ‘04, so I’d like to know this as well.
But to be productive, maybe put a meter to the posts on the side that isn’t working and do a continuity test? If you get tone on the side that works, but not on the side that doesn’t, I suspect you got a bad windshield.
Old 11-19-2022, 07:44 PM
Trailmix's Avatar
Originally Posted by longtallsally
Ooh, I can’t recall how it was on my ‘00, but I’m going to put a heated windshield in my ‘04, so I’d like to know this as well. But to be productive, maybe put a meter to the posts on the side that isn’t working and do a continuity test? If you get tone on the side that works, but not on the side that doesn’t, I suspect you got a bad windshield.
turns out that my passenger side fails the resistance test (no resistance), so that's the reason my passenger side wasn't working. I'm still not sure why the plug wires don't match, or whether they should. That may also be an issue.
Old 11-19-2022, 09:09 PM
greisinb's Avatar
When you say "fails the resistance test" are you referring to the windshield not having any resistance or the truck side having no resistance? Your windshield should definitely have resistance because the heated windshield is a giant resistor and the truck side should be an open circuit when the heater is off (and 12V when on). The colors on the plug shouldn't matter, the heating element in the windshield doesn't care about the polarity of the electricity.
Old 11-19-2022, 09:40 PM
Trailmix's Avatar
the windshield side on passenger side has no resistance.
Old 11-20-2022, 10:58 AM
Brandon318's Avatar
It won’t work if there’s even one tiny break in the filament inside the glass. This might be the cause.
Old 11-20-2022, 11:27 AM
XRAD's Avatar
I'm pretty sure that would be a terrible design. I have one or two bad elements in my windscreen, and the rest still work. Like the rear window defroster...front is likely a parallel set of resistor elements. Probably the tape connector fried/failed....
Old 11-20-2022, 11:30 AM
Brandon318's Avatar
¯\_(ツ)_/¯ I very well might be wrong but I've read this elsewhere long ago when I first got our disco and was trying to figure out why the windscreen wasn't heating. It ended up being that it needed to be "activated" by the Nanocom.
Old 11-20-2022, 02:10 PM
disco96sd's Avatar
never did understand why ROW landy's got the heated front windscreen and we got a defroster - makes zero sense - must be some big government regulation
Old 11-20-2022, 04:47 PM
Extinct's Avatar
Received 1,506 Likes on 1,068 Posts
No it was an option in the US, I have several that have the heated front screen.
Quick Reply: heated windshield plug/wire
