Heater Blower motor/fan Disco 1
Old Feb 24, 2010 | 05:01 PM
okdiscoguy's Avatar
easy to pull the motor. Pull the trim below the glove box and whammo, there it is..
What is it doing?
Old Feb 24, 2010 | 06:24 PM
The dash switch goes out more than the blower motor on a DI.
Old Feb 25, 2010 | 12:35 PM
Cirrus's Avatar
Well, Here's the deal. My truck nearly burned up the other day. I had a eletrical short occur on the blower circuit when it was turned on. I was able to remove the motor. To my suprise the motor is seized. I replaced the motor but now the switch will not turn it on. I have confirmed that there is power coming from the switch to the motor. I also confirm the replacement motor works. My question is the resistor pack for the switch, can it go bad? The switch itself seems to light up the test light that I am using. Any ideas would be great. Thanks.
Old Nov 15, 2010 | 04:42 PM
LANDROVER LUKE's Avatar
yes the resistor can fail also--the switch fails ussually in way that the blower just stops blowing but tap the switch and it will start again---your problem does not blow on any speed???if so i say resistor
Cirrus
Oct 21, 2021 09:50 PM
angrylobster
Jun 28, 2015 04:43 PM
03discoken
Mar 9, 2015 03:47 AM
nelbra
Mar 21, 2010 03:30 PM
newf4us
Freelander
Nov 5, 2007 06:59 PM
