Help! Big Trans Problem
Old Oct 14, 2010 | 08:51 AM
vandal996's Avatar
Default Help! Big Trans Problem
I drove the truck and parked it. When I got back in and put it in gear it would not move. When I put it back in park it makes a grinding clacking noise. It wont move under power in any gear however it rolls freely in all gears.
Any ideas?
2003 Disco 2. 87,000 miles. Recent top end rebuild.
Old Oct 14, 2010 | 08:56 AM
vandal996's Avatar
Just subscribing to the thread.
Old Oct 14, 2010 | 10:13 AM
hilltoppersx's Avatar
are you sure its a transmission problem? have you had the drive shaft rebuilt? have you climbed underneath the truck?
Old Oct 14, 2010 | 11:53 AM
tweakrover's Avatar
transfer case is in neutral or something in the driveline is broke.
Old Oct 14, 2010 | 11:55 AM
tweakrover's Avatar
if you pull the parking brake and it still rolls it is in the rear, if it stops it from rolling it is in the front.
Old Oct 14, 2010 | 06:14 PM
Danny Lee 97 Disco's Avatar
Doesn't the parking brake lock the driveshaft? I find your answer somewhat bewildering, please explain.
Old Oct 14, 2010 | 06:39 PM
lipadj46's Avatar
He is saying the parking brake locks the rear driveshaft so if the truck rolls with the parking brake on the rear shaft is broke.
Old Oct 14, 2010 | 06:46 PM
timdunbar's Avatar
I bet your front driveshaft let go, look under the truck you will be able to tell if somethings wrong.
Old Oct 14, 2010 | 06:47 PM
IDAHO's Avatar
If it can roll, you can push it off something. Just a thought.
And from my experience it doesn't sound like a tranny issue. I think you could be looking at a transfer case issue(Not in gear/locked).
Old Oct 14, 2010 | 09:25 PM
tweakrover's Avatar
what he said
