Help. Broke down. Alternator?
I'm broke down on the side of the road with 5 kids in 6" of snow. Battery symbol light came on and a bit later m-s lights began flashing as well as the other lights. Vehicle is dead now and won't turn over. I assume I'm looking at a classic alternator failure . Anything to check to verify? Fuses in underhood box seem fine.
Sounds like the alternator. Do the headlights or interiors light come on almost normal or are they flatline? Still check the leads to the battery.
If you get power to the lights, turn ALL electrical OFF > and listen the the Alternator. If you hear a low hum/buzz the bridge rectifier is toast.
If all else fails it looks like you will be calling Land Rovers Parent Company..... AAA
Thanks for the replys ! just finished installing my new alternator from advance auto. I hate putting on crap parts but, when your broke down on the side of the road and its the only alternator in 50 miles. A new bosch unit is $950 everything else from other companies is just re-manufactured bosch. One thing has me worried the sticker on the alternator and the box indicate its the required 130 amp but, the black plastic housing on back of alternator is printed that its a 115 amp? anyway its back up and running fine now.
thanks again.
thanks again.
That is some BS! So they should have sold you #12045 but they gave you # 12022
How did the 7 rib Rover belt fit the 6 rib MBZ pulley? Did you have to use your old pulley or is this really F'd up?
What a day from hell. Snow, 5 kids, a DII, and Advance Auto Parts counter monkeys. Hope things get better soon!
