HELP!!! Firing Order
Old Dec 29, 2007 | 06:51 PM
jspbtown's Avatar
Default HELP!!! Firing Order
OK...swapped out the old plug wires with the Magnacore wires and I think I mixed one up. It will run...but has a little skip down in the low RPM range. Can someone give me a firing order diagram?
2004 Disco. Two coil packs. As detailed as possible please. 4 across the top, 4 across the bottom, then left and right cyclinder banks. Please clarify if the diagram is looking at the engine (ie: drivers side right) or the standard left drivers side.
Please help asap!
Jeff
Old Dec 29, 2007 | 06:55 PM
okdiscoguy's Avatar
Default RE: HELP!!! Firing Order
8 5 6 1
2 3 4 7
8 7
6 5
4 3
21
try that..
Old Dec 30, 2007 | 09:31 AM
jspbtown's Avatar
Excellent! I will go out and try right now!
One more question......
On the drivers side firewall, near the brake booster, there are a series of hard plastic lines attached to the firewall. The bottom one isn't attached to anything when it comes out from the side towards the engine. I don't know if I knocked something off or if it is supposed to be that way. I can't see any loose hoses anywhere.
Old Dec 30, 2007 | 10:23 AM
jspbtown's Avatar
Well #8 and #2 were swapped. Easy fix. And a BIG THANK YOU!
Still wondering about that plastic tube.
Also, and I feel like an idiot to ask but....where the hell is the fuel filter? I have been up one side and down the other looking for it!
Old Dec 30, 2007 | 10:34 AM
jspbtown's Avatar
OK...so I searched....no fule filter on a 2004 Disco II??? That correct????
What the heck did Parts America sell me then? Looks like a fuel filter.
Still wondering about that plastic line.
Old Dec 30, 2007 | 12:47 PM
okdiscoguy's Avatar
No Fuel filter. Just a sock on the pump in the tank.
On the hose, can you post a picture? if not, someone with an 04 will have to help you..
Old Dec 30, 2007 | 04:24 PM
JEFIII's Avatar
Just checked my '04. The plastic hose that comes from behind the booster that is NOT insulated isNOT connected to anything. Hope that helps. JF
Old Dec 30, 2007 | 04:30 PM
That plastic hose is a vent, most likely for the front diff.
Old Dec 30, 2007 | 07:01 PM
jspbtown's Avatar
Whew! Thanks guys. I didn't think I nudged anything but it was tight quarters getting those wires off. One boot was cracked which I assume was the reason for my sporadic mis-fire (mostly when it rained).
Getting my 6"2" 240lbs frame up under that hood and getting my hands down there was not easy! I actually used a long aluminum tube (a rear fender support for my Meyers Manx dunebuggy, to get down there and pry the old ones off.
Old Dec 30, 2007 | 07:09 PM
okdiscoguy's Avatar
What wires did you go with?
