HELP! Let me explain. Lol
1 Attachment(s)
Ok, so I picked up another disco 2. I have attached a video. Now it may be the head gasket but before we get there hear me out. The motor was replaced in 22, then it was repaired due to an exhaust leak? So, the gem of a mechanic says the exhaust manifold didn’t line up so he double gasketed it. Please send me some advice before I rip the heads off! Not sure if the video posted or why it isn’t posting
https://cimg3.ibsrv.net/gimg/landrov...a056b7bda6.png https://cimg4.ibsrv.net/gimg/landrov...8deaa431ef.png |
My manifolds to the head are also double gasketed and from what I understand, that's normal. I'm putting heads back on and going to also double gasket in the same place they already were.
With it cold, put your smoke tester into an O2 sensor hole and see if it's just leaking at gasket or cracked. I use a tire valve stem backwards to plug up O2 sensor port when smoking exhaust. |
Originally Posted by Roont
(Post 891295)
I don't see a video. Sometimes it's easier to put it on YouTube and share the link?
Sometimes things don't line up, especially on our 20 year old vehicles, wear, rust, unreported damage, bashing around on crane when removing old engine, someone getting flat rate and not having time to adjust forever, not-perfect new parts that kind of but not really fit Someone with more land Rover experience might have better information on the double gasket. But I'd smoke to find exhaust leak first and do my own diag before spending money |
(Post 891295)
here’s a link to the video |
I saw the video. It sounds like an exhaust gasket leak at the inlet, but have you checked the outlet? Sometimes it's not an alignment issue but a flatness issue. If you stick your hand in there you should be able to feel the puffing.
It sounds like either an upper engine tap on that side or an exhaust leak, you're right. When it's running can you feel air chuffing around manifold?
Can get a scope in a spark plug hole to see if a valve is flapping about or maybe easier to just pull off lower intake and feel for play in the rods? |
Originally Posted by ahab
(Post 891302)
(Post 891303)
