HELP looking at buying a disco
There is some difference between 99-02 and 03-04. The 03-04 basically had a facelift and got some new headlights and tail lights. Other than that, they are the same truck.
Stay away from 03's, there were many with oil pump failures.
I know you said 01-04, but consider 99-00 because they have the ability to add center diff. lock (CDL) and that comes in handy if you want to use your Disco off road. Some 01's have it too, but only the ones built early in 2001. The 2004 model has CDL stock, and some consider it the best year of the disco.
Be sure to check if the maintainence has been kept up with. That will make a huge difference down the road. If you can find one that has been well taken care of, you'll have a much better ownership experience.
Love my DII
I have an '02, so no CDL, I don't do any "heavy" off-roading, or have enough bad weather up here and don't think I'll ever really need it (famous last words).
My best advice would also be to find one that's been well taken care of and you will be happy, just be sure to continue the good maintenance habits or your beloved Rover will quickly turn against you.
Thanks for the insight. I do live in the midwest where we get plenty of snow so the CDL would probably be a good idea. Are there any other major things i should look for. As far as the engines go do they all have major problems around 100000, or is this just the people that bitching that has problems?
About all we will hear on here is problem trucks.
Expect head gaskets in the 80-100k range, so if you get one with over 100k that should be taken care of already.
Read the write up section, that covers alot.
Take your time and test drive as many as you can.
Here you go , only 3k on the od....this should last a couple years...
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
LOLZ... how is that possible.. 500 miles a year..
I bet the seller has never had a disco on his lot before and knows next to nothing about them. He thinks he has a diamond and really its a ticking time bomb. On the other hand I noticed that they specified NO Warranty and didn't mention giving one anywhere so maybe they are just hoping for a sucker to come along. Looks pretty though.
