Help With Motor Swap Codes
Received 1,189 Likes
on
Tough part about this whole process...is the fact we have no previous information about this engine. Me, if l were in this position...l'd head back to the beginning...of engine diagnostics. And since it seems to be consistent with codes, which is a good thing...l'd pull the plugs and do a compression test at this point. I'd need to know the mechanical soundness of engine...especially, to move forward looking at other posibilities. If l noticed any irregularities in the compression test, next would be a cylinder leakdown test. If compression test is good, and since you've changed/tested coil packs/wires/plugs, and since you aren't getting any vacuum or 02 related codes...my next best guess would take me to the injectors. I know you said the injectors were new, so look at harness or plug issues.
Brian.
Brian.
Mwells (04-23-2020)
Could it be bad O2 sensors causing the misfire?
I’ve read it has helped others with their codes but I’m not getting any O2 codes.
With no check engine light I ran the scanner and get the 1514 code and 1553. Rev the engine and I get the 1,7,4,6 misfire with 1300. No other codes.
Checked all the relays and grounds once more.
The Deputy (05-17-2020)
