HELP! need ideas
Old Mar 30, 2009 | 07:23 PM
pilsner's Avatar
Default HELP! need ideas
ok, base line:
2000 discovery II w/141k
new plugs/wires/airfilter/MAF/crank position sensor
vehicle is up to date on maintence except for 3 amigos
problem:
when at idle truck runs fine.
when i put it into drive vehicle will behave normally until 1800-2000 RPM and then vehicle loses all power with RPMs dropping to less than idle. vehicle top speed is approximately 11 MPH. rover occasionally dies, but will restart immediately. this happens when vehicle is both hot and cold.
any idea on what to try next?
btw no error codes (other than P1590 - ABS 3 amigos, we are old friends...) and no check engine light...
Old Mar 30, 2009 | 07:27 PM
So with it in park or neutral you cant rev it past 2,000 rpm?
With it in drive you cant go any faster than 11 mph?
Old Mar 30, 2009 | 07:56 PM
pilsner's Avatar
in park or neutral it will rev to redline with no issues.
in gear while trying to move in a forward direction it will only go to 10 or 15 mph.
then it loses power...
Old Mar 30, 2009 | 08:11 PM
Then it s a transmission issue.
Have you checked the trans fluid lately?
Old Mar 30, 2009 | 08:28 PM
pilsner's Avatar
wouldnt tranny give off error codes? why would engine die? mike didnt say anything about tranny.
even at idle it doesnt seem as "strong" as it should be
Old Mar 30, 2009 | 08:31 PM
When did you talk to Mike?
Old Mar 30, 2009 | 09:19 PM
pilsner's Avatar
just a few hours ago. even he seemed baffled by this. he recommended that i check the MAF o-ring. then cross check the MAF by switching it with xb70valkaries (if he is willing to drive the 90 min to help out - hint hint fred...) which we know is working properly. assuming the new MAF and oring are working as they should the only thing left is cam position sensor.
if i understood properly a malfunctioning Cam sensor will mess up the fuel injection sequencing thus makeing it run poorly. but i may have that wrong.
ideas?
what is f@cking us up is the lack of error codes or check engine light.
Old Mar 31, 2009 | 03:11 PM
There are no codes because it is a transmission problem.
Old Mar 31, 2009 | 04:31 PM
That tranny has codes that run from 700 to 800, if there were a problem, believe me it would show up, rull the tranny out.
Did you swap out the MAF yet?
Old Mar 31, 2009 | 07:29 PM
okdiscoguy's Avatar
Sounds like a MAF to me... Just so Spike feels better, does it sputter to 10MPH, or run fine and then rev around 10 MPH? With it in gear and your foot on the brake, hit the gas pedal. If it doesn't move or feel like you have power, I am still betting MAF.
