How is a 2" lift going to effect my MPG?
My truck is in need of new shocks, I'm at 150k so I figure I should do springs too. It seems cheaper to do a TF 2" than to get factory springs, but I'm concerned about the increase in MPG with the lift.
What have been your experiences with MPG after a 2" lift?
Engine performance has greatly improved... The slight stumble at idle is gone. The slight hesitation under acceleration is gone... It pulls better uphill...
I've had a chance to drive it around town and on a highway run...
City MPG 13.5 - up from 10.2
Highway MPG 16.4 - up from 12.2
This was all prior to the lift and larger tires...
With premium fuel running around $4.00 per gallon here, it won't take too many tanks of fuel to pay for the sensors... Sensors equaled about the same as 50 gallons of fuel at $4.00 per gallon or $200.00
10 is way too low. Assuming you aren't driving like a lunatic, depending on what the check engine light is on for it may dramatically affect the mpg's
I have 265 rugged terrains and they are 32.8 inches and E rated. I get 13.7 according to the ultra gauge. Of course it's here with my at the garage in work after I or hit on Thursday. Their limo company insurance is trying to just not answer so I'll be pushed to use mine. I would have done anything but now I'll push for compensation, I'm hurt right. I said all that cus I'll take that money, drop a 3.3 cummins and Allison tranny. Place out of Montana is doing it. The engines meet EPA standards so it is the cheapest most function I've found.
