How bad is the wear on this crankshaft pulley?
Hard to tell on the grooves from the pictures. Mine looked similar and leaked like a sieve with the new seal. You can offset the new seal to miss the grooves or use a speedisleev. I did the speedsleev and it worked great. As fo the rubber, I can't say. They all look like that and new ones are $$$$$.
Rule of thumb is...if you can feel that groove with your finger nail...it has to be addressed. Which that deepest groove looks substantial enough to be an issue. Either use crocus cloth to lessen the ridge/edge of that groove (which will allow seal to ride flush against surface again) or move seal in farther or out a bit to not ride on that surface after cleaning it up with crocus cloth (hopefully, you haven't removed it yet so you can make decisions on location of new seal) or speedy sleeve.
Me, l'd hit it lightly with some crocus cloth, start with maybe 80 grit, then 120 grit, working in an even/circular motion around the entire area/trying to create cross-hatch marks (similar to honing a cylinder bore) and make my detremination on whether or not it's any good. If too much sanding/crocus cloth work is required...then use speedy sleeve.
The cracks in the rubber look superficially to me. If l was basing my decision on whether or not to reuse it solely on the cracks...l'd reuse it.
The following 4 users liked this post by The Deputy:
The Deputy (07-23-2021)
I could barely feel the groove on my pulley shaft either, it leaked nonetheless. Not pushing the seal all the way in seems to be an old mechanic's trick. The downside is, that the seal might fall out (happened to me after I bought the truck). At least I would sleeve the shaft, if not buy a new pulley.
Brandon318 (07-23-2021)
