How to change transfer case fluid?
@MyOldCars There are lots of flat bars with 1/2 drive male on them, just check your automotive parts store. https://www.kmstools.com/performance...BoCLUEQAvD_BwE
Also, there is an upgrade kit, which will turn an existing non-cdl t-case into a cdl one, but that kit is like over $700. On Luck8 I think.
You can buy a CDL transfer case (they were in all of them from 99-01) and swap the nose off of it in to yours without removing the transfer case. 97 D1 linkage will work but not as elegant as 04 shifter cable.
Not all 01’s. Mines an ‘01 and it didn’t come with one.
It seems that LR thought their TC was so good that CDL was no longer needed. I think to a large degree they were correct, but I think CDL does give an extra edge under more extreme conditions.
If it's an urban crossover SUV for moms and dads to drive their kids to soccer and lacross practice and to go to Costco and stuff - yes, you don't need a CDL.
If this is a serious SUV that competes with certain Toyotas (Land Cruiser, Prado, 4Runner, etc.) and few other true SUVs that were still out there in late '90-s and early '00s, then you DO NEED the damn CDL, which you really had all along in the first place.
This is stupid, and I don't get it.
You're a mexi-can or a mexi-can't. As one guy said once in a certain movie ))
I have a 99 t-case I'd sell if you pick it up with the correct nose, no linkage tho. cheapest solution there is to find a d1 in a junkyard and go get it yourself. have not heard good things about fitment of the ashcroft kit and don't trust L8 for much more than they will with no uncertainty have the worst website lol
D1 Transfer case will also work. Just have to change the front flange over for the front drive shaft so technically 94-99 D1 then 99-02 D2 (depending on production date or if the TC was replaced say in late 02-03 under warranty), and 04 D2 of coarse.
