How do you raise and lower a power window in a junk yard?
If it's easy grab it.
thanks
I just saw a video on youtube from BA showing how to remove that piece.
If any of the the 3 metal clips or rivets don't want to cooperate and you have to grab the rivets with pliers or something to force them out, I still have mine (clips and rivets) on the truck so no problem.
This is for another truck I bought a couple of weeks ago and a-pillar cover was missing when I bought it. I can see where it broke off, part of it is still under the rivets.
thanks and like I said it if turns into a hassle or breaks just leave it no problem.
Take it from someone who has removed plenty of these plastic a pillar covers, that video is a joke. Yeah, it's that easy to remove the cover if you have no plans of reusing it.
Trying to salvage one is an entiry different matter . That's why people who resell perfect covers with all the plastic mounts undamaged, charge what they do.
I used to buy boat motors from the state to salvage/sell parts and I do know that some parts are worth less than the labor involved to remove them.
thanks and hope it don't get too hot out there and hope your door parts come off without a hitch.
hey doc after looking at my other 03 and feeling of the covers I think at least 2 of the clips mounts are broken on one side and maybe 1 on the other side and they still stay on and look fine. I'm not building a show truck just something to kick around in. Anything mechanical I like to fix perfect but something like that..don't matter. I'll probably just tear it off with a tree limb anyway!
thanks
thanks
Ok, I'm back.
I pulled the window frames using Paul's instructions. I had them both out in 20 minutes.
Then I pulled the driver's side A frame cover for practice. It pretty much came right off. So I pulled the passenger side, and it was easily twice as hard to get out. I ended breaking the top clip, but otherwise it's good. RicketyTick, I'll pm you the total when I have it packed to ship.
Then I started looking for stuff to grab. I pulled the drivers side rear lock because mine's dragging. I pulled the ABS modulator switch, because I suspect mine has failed. I pulled the rear wiper arm because I'm gonna try to mod it so I can replace the blade. I got the rear cup holder. Tip: straighten a couple of hose clamps and slide them in the ends of the cup holder and it slides right out.
I just realized I forgot to grab the front cup holder, which I planned to get as a spare. I wanted the rear door handle cover (back of the truck, next to spare), but the rear door was stuck closed. I thought about grabbing the ABS modulator itself, but it was $50 and the hose nuts were really stuck. I'm trying to think if there's anything else I should grab. The alternator's gone. I didn't check to see if the starter is still there, but I probly should have grabbed it.
It ended up being $83 total.
Thanks for all the help, fellas!
Cool, glad you were able to get it! no hurry packing and shipping, I have to transfer funds over to paypal may take a day or two to show up in my account. They waste no time taking money out but don't get into any hurry putting funds in.
Doc you just don't know how much I appreciate that! Next time I'm headed to New Orleans or Baton Rouge to a u-pull I'll let you know so if you need anything. I don't go often but am making a list.
