How to remove this pipe connection
https://cimg6.ibsrv.net/gimg/landrov...7bc3d44f4.jpeg I used my smoke machine and found a small leak where this connected is how easy is it to remove? I know how to release the tube itself just not the connector |
push red thingy in, pull tube out
I was talking about the actual connecter |
Originally Posted by escott16
(Post 658092)
I used my smoke machine and found a small leak...
If you smoke...just have someone blow smoke into the system my buddy does this and it works all the time.
I have a snap on Evap machine , I’ve seen the diy ones if I didn’t have a snap on I’d make my own, didnt have any luck using a cigar I couldn’t get enough smoke or pressure to see where the smoke was coming from |
Originally Posted by JUKE179r
(Post 658136)
Off topic but did you make the smoke machine or buy one? I'm looking at getting one to check for hose leaks too.
Haven't used it yet, but it looks like a good cheap tool. Real smoke testers are $$$ |
