How to remove this pipe connection
Old Aug 13, 2018 | 06:13 PM
escott16's Avatar
Default How to remove this pipe connection
I used my smoke machine and found a small leak where this connected is how easy is it to remove? I know how to release the tube itself just not the connector
Old Aug 13, 2018 | 06:47 PM
Jeff Blake's Avatar
push red thingy in, pull tube out
Old Aug 13, 2018 | 08:11 PM
escott16's Avatar
I was talking about the actual connecter
Old Aug 13, 2018 | 08:18 PM
Jeff Blake's Avatar
My bad. It's a press fit. Just pop her out
Old Aug 14, 2018 | 03:59 AM
JUKE179r's Avatar
Originally Posted by escott16
I used my smoke machine and found a small leak...
Off topic but did you make the smoke machine or buy one? I'm looking at getting one to check for hose leaks too.
Old Aug 14, 2018 | 04:40 AM
shanechevelle's Avatar
If you smoke...just have someone blow smoke into the system my buddy does this and it works all the time.
Old Aug 14, 2018 | 07:17 AM
escott16's Avatar
I have a snap on Evap machine , I’ve seen the diy ones if I didn’t have a snap on I’d make my own, didnt have any luck using a cigar I couldn’t get enough smoke or pressure to see where the smoke was coming from
Old Aug 14, 2018 | 12:38 PM
Jeff Blake's Avatar
I have one of these: https://www.ebay.com/itm/EVAP-Smoke-...ke+tester.TRS0
Haven't used it yet, but it looks like a good cheap tool. Real smoke testers are $$$
Onlyrovers
Mar 20, 2019 06:39 PM
CaptainClif
Mar 19, 2019 05:06 PM
slobdogg
Feb 28, 2019 06:35 AM
LR03NJ
Jun 28, 2018 10:24 AM
ROB99DISCOSD
Jan 14, 2018 09:34 AM
