How should I bypass T-state on 04' Discovery?
I need to bypass my thermostat on my 2004 Discovery so I can run it and flush the cooling system while I wait for the new T-stat to be delivered.
Can I simply remove the damaged T-stat and use a T-hose to make the connection or, is it more complicated than that? Thanks for your help. |
Whats wrong with the old tstat? If its not leaking you can remove the innards carefully...
Thanks... yes... it is leaking. Thoughts?
You can use a plastic pex plumbing tee
Or 1" galvy fittings from home repair place hd or lowes Plastic pex pieces or irrigation pieces will be cheapest |
Thanks dusty1. I needed confirmation from someone more experienced than I. I appreciate your advice.
