How should I bypass T-state on 04' Discovery?
Old Feb 8, 2015 | 01:35 PM
Newbeige's Avatar
7th Gear
Default How should I bypass T-state on 04' Discovery?
I need to bypass my thermostat on my 2004 Discovery so I can run it and flush the cooling system while I wait for the new T-stat to be delivered.
Can I simply remove the damaged T-stat and use a T-hose to make the connection or, is it more complicated than that?
Thanks for your help.
Old Feb 8, 2015 | 02:41 PM
zski128's Avatar
Whats wrong with the old tstat? If its not leaking you can remove the innards carefully...
Old Feb 8, 2015 | 02:53 PM
Newbeige's Avatar
7th Gear
Thanks... yes... it is leaking. Thoughts?
Old Feb 8, 2015 | 02:58 PM
dusty1's Avatar
You can use a plastic pex plumbing tee
Or 1" galvy fittings from home repair place hd or lowes
Plastic pex pieces or irrigation pieces will be cheapest
Old Feb 8, 2015 | 03:17 PM
Newbeige's Avatar
7th Gear
Thanks dusty1. I needed confirmation from someone more experienced than I. I appreciate your advice.
Busch297
Mar 4, 2017 08:41 PM
N.Franklin
Appearance & Camping Set Ups
Feb 20, 2008 03:53 PM
hendoc3
Off Topic
Aug 28, 2007 01:46 PM
Justmealex
Sep 16, 2006 06:55 AM
05LandRover
Off Topic
May 1, 2005 02:29 AM
