How smooth is your idle?
I have had my '03 for about 3 weeks now and something I have noticed is the idle is a bit choppy, not real bad, just kind goes smooth, choppy, smooth, choppy so and so forth. Do these trucks idle a little rough? Im new to land rovers so I really dont know. It has new plugs, wires,air filter and head gaskets and no check engine lights on. Im working through the major service stuff, so far all diffs and transfer case fluids changes as well as power steering and front drive shaft rebuilt. Any thoughts on cause or normality of the idle issue?
thanks-jon
thanks-jon
What does it idle at? Does it fluctuate? If so, between what and what? Does it do it more cold or hot, or same either? Rough idle basically boils down to ignition, fuel, and what goes on in the chamber. Could be as simple as bad plugs or wires. Could be a vacuum leak, poor compression, dirty injector, etc...
Idles at about 750 and the needle hardly even moves, if you watch it close it will flucuate very slightly. It idles like this hot or cold but, you still notice it a little bit when its idle high with a cold startup. Other than that it runs really smooth, just this irritating idle. thanks for all the replys!
