HUB STILL LEAKING??
Hello All,
I am at work and need to order a socket big enough to remove the axle nut to replace my rear hub... What size is that nut? THANKS!!
Josh
Josh
XD-DII's have a single non servicable hub, like on a front wheel drive car.
http://www.roverparts.com/Parts/CDU1534L.cfm
JYC-I think it is a 24mm.
I called the parts dept at a dealer in Fl and was told it was 36mm by a mechanic... I have a 30mm socket and it is too small to fit over it. I have had misleading and incorrect information from dealers before so i was hoping someone on this forum could tell me. I can find out myself but not until the weekend. =(
Ok it is a 36mm nut.
But now i need to remove and replace the hub. I have removed the hub and of course the drive shaft comes out with it. I need to press the drive shaft out of the hub and press it into the new one.
Has anyone done this before? I think using some type of gear puller might work to pull it out. Any suggestions?
Thanks
Thanks
Yeah I figured that would be a challenge... but thats no problem...I have a friend who works on big rigs who might just have the tool needed for that part. Other than that, you think a gear puller will do it? I guess its worth a try!
