On the hunt for ABS module for CDL. Am I looking for SRD 500070?
It's like this... SRD500070 > SRD000150 > SRD000070
From what I've read since I am looking for an SRD500070 SLABS unit, the SRD500070 is slightly more electronically modified than the SRD000150 unit. I don't think anyone knows the exact specifics are between the two units.
The SRD500070 was the only SLABS unit for a Disco 2 that was manufactured in Poland and is stamped on it's part number sticker. I've seen some SRD500070 units have a manufacture date from 2004 to 2011 which was way after LR stopped production of the Discovery 2.
The SRD500070 has been labeled as the Holy Grail since they are so hard to come by but they are out there. They can be expensive from $500- $900 on eBay.
the three models are all slightly different. srd000070 isn't "cdl-aware" so it gives an error under certain situations if you have the transfer case locked.
the abs mapping is supposedly different between srd000150 and srd500070. i assume that it is different on the first model too.
i believe that i have all three units, although i haven't used them all in a cdl-equipped truck yet. once i get the lockable t-case into my 2003 truck i might do a little bit of testing. (i'm assuming that the srd000150 is in that truck from the factory. i definitely used both of the other two in my '99 truck.)
i found the srd500070 on ebay for about $50 last year.
I believe that I have one. I can check for you tonight. $50 plus shipping would do it. I used it when diagnosing three amigos, which ended up being a wheel speed sensor. So, it may need codes cleared, but should be good to go. I don’t think I will ever have a use for it.
i believe that i have one. I can check for you tonight. $50 plus shipping would do it. I used it when diagnosing three amigos, which ended up being a wheel speed sensor. So, it may need codes cleared, but should be good to go. I don’t think i will ever have a use for it.
