I need some help on my 01 Disco II!!!PLEASE
Just recently bought a disco 2 and driveshaft broke. Took to a local shop and had new u joints and shaft installed. Now over 20mph there is a vibration that is really annoying. Any ideas? Also local shop diagnosed power steering leak was pressurized hose going to the box. Replaced.... After a day it was leaking while sitting...again I plead any ...any ideas???
Unless it was the rear, which has no centering ball.
Is it leaking from the same hose? if it is, take it back to the shop to fix properly, it should be under warranty. It could be leaking elsewhere, if they disturbed another hose installing the high pressure hose.
You should have made sure they knew what they were doing, I am sure they didn't replace the center ball kit either. Quit driving it till you can find someone to build it properly.
By the way, I have had mine rebuild 2 times and never had to have it balanced, cause when done right, it is not necessary.
Advance Auto carries them
Nepaco 7-0081NG
Or Precision 617 from most autoparts shops.
Take it to a driveline shop to get it done, or at least to get it balanced after you do it. I suspect that the shop that did it the first time didn't reassemble it with the parts in the correct relation to each are and it's probably out of balance.
Once it all back in place be sure you grease it properly, as described in this post.
https://landroverforums.com/forum/sh...8&postcount=11
Nepaco 7-0081NG
whurst79
01-28-2013 09:24 PM
Billabong
01-27-2010 12:36 AM
StormTroopa
08-09-2009 05:26 PM
97DISCOIDAHO
09-08-2006 11:56 PM
