I want to lift my baby
Old Nov 19, 2010 | 01:55 PM
bsnapp818's Avatar
Default I want to lift my baby
I want to lift the little lady. Im not exactly the richest kid on the planet and want to do for as little as possible. Spacers? or full on kit? I see both listed and I'm just curious as to what the ride on the spacers would be like.
Old Nov 19, 2010 | 02:07 PM
hilltoppersx's Avatar
what do you plan on doing with your truck? spacers will gain you an inch of body lift. you can get 2.25" from a terrafirma lift. to increase that lift you will need bigger tires which the spacers or lift will provide. you are looking at $900 for a lift and 4 tires that can get you around 5" of lift depending on tire size chosen.
Old Nov 19, 2010 | 02:40 PM
bsnapp818's Avatar
This will be more for looks. I live in Florida and lets face it, if I go on any trails, there isn't much in the way of elevation change. I have already been looking at changing the size of my tires, and I just found spacers that say there will be 2.5" of lift. I'm new to the whole world of Land Rover mods. I need help!
Old Nov 19, 2010 | 03:21 PM
if i were you i would get a terrafirma +2 kit from Lucky 8 and a set of four howler or guard dogs from treadwright and call it done. do you have 16" or 18" inch rims?
Old Nov 19, 2010 | 07:00 PM
Fireman's Avatar
bsnapp818, before you do your lift, have you rebuilt the front DS or done the 60K major service? If not, you may end up with a 4500 lb rock with a 2" lift. Do the basics first...
Old Nov 19, 2010 | 10:18 PM
mwindth's Avatar
I concur 100% and would also add an oil pressure gauge and accurate temp sensor first before any lift being it is an '03. Just my opinion...
Old Nov 19, 2010 | 11:15 PM
bosshogt's Avatar
Here is the Terrifirm kit for $642 including shipping. I agree do the drive shaft and the oil gauge. I have a 2003, those are essential for piece of mind.
TERRAFIRMA ALL TERRAIN HD SUSPENSION KIT - DISCOVERY II
Old Nov 20, 2010 | 09:42 AM
bsnapp818's Avatar
I have 18" rims... So I should do something about my drive shaft first huh?
Old Nov 20, 2010 | 10:58 AM
NiteTrain's Avatar
yeah replace U-joints with greaseable U-joints
Old Nov 20, 2010 | 11:09 AM
mwindth's Avatar
bsnapp818...I can write with confidence that everyone on this forum would agree that re-building the front u-joints and centering ball with greaseable parts should be your first priority...when they fail (not if, when), they usually knock a hole the size of your fist into your transmission...check this sticky for details and other excellent tid-bits: https://landroverforums.com/forum/sh...ad.php?t=26352
Then hit Lucky 8 up for the Terrafirma...
