Aren’t we supposed to get rid of the oil separator when we do the PCV mod?
Originally Posted by Harvlr
(Post 895445)
Exactly. I removed mine per PCV MOD. Developed a surging idle, reinstall oil separator valve and the surging idle had not come back. |
Originally Posted by Frank4
(Post 895332)
... I also replaced the plastic connector at the intake that the hose from the valve cover connects to with a brass fitting. ...
The PCV mod requires a PCV valve to be installed at the upper intake manifold, not just a "brass fitting". What did you install there? |
Ah ha. That’s where I went wrong. I used an NPT valve! Straight through I guess?
Yeah, I used the brass plumbing fitting for 10 years after I broke the original plastic fitting and before I did the PCV mod 4½ years ago.
The one I used was for my air compressor.
