Idle issues / bumpy Idle
Hi everyone, I'm having the idle issue? I checked out the rough idle thread and never saw the final fix if there was one??
I have changed out coils ,plugs,!wires and maf sensor. Still having the same bumpy Idle?
It did seem that when i Changed Coils and wires it ran better for a while. But started again?? Changed out maf sensor, ran ok during test drive, but in the morning same old again??
any help with this issue will be most appreciated! Made an appointment with my mechanic for Monday.. just wanna point him in the right direction!!
Thanks again in advance!
Have you cleaned the Idle air control unit? I had a low idle on cold startup way back, ended up being a sticking IAC. Brake cleaner fixed it. Maybe not your issue, but it takes only a few minutes to clean and rule it out.
Don't worry if the IAC valve rattles when you shake it. It's supposed to do that.
