Idle problems
Old Oct 8, 2009 | 07:34 AM
DDP's Avatar
DDP
Default Idle problems
i did an induction clen about 2 months ago, then i flushed the radiator and heater core this w/e ,and i started having idle issues at cold it idles great then once warm it will go to about 1200 to 1400, so last night i pulled the iac and cleaned all the carbon off the valve and cleaned the hole it goes in, started the vehicle and it was great so i drove about 30 miles still great, this morning its back to over idle at 1200 , ------------ could i have something wet from when i flushed the cooling system or does anyone know what i should do next? and also i can jiggle or flutter the throttle linkage and the rpm will fall and almost shut off the engine if i keep on .
1998 disco1 111000 miles
Old Oct 8, 2009 | 08:05 AM
okdiscoguy's Avatar
Did you clean the throttle body when you did the induction cleaning?
Old Oct 8, 2009 | 09:09 AM
Yes, you could have gotten something wet, especially with a D1, when doing a coolant flush, but iw would have dried out in a day or so so that shouldn't be a concern now.
As already asked, have you cleaned your t/boy also? You might also want to check all your vacuum lines and seals for a leak.
Old Oct 8, 2009 | 09:23 AM
DDP's Avatar
DDP
yes i did a throttle body clean again last night when i did the iac valve, i have also traced all vacum lines and found no leaks??????????? could it be the tps ? can it be tested
Old Oct 8, 2009 | 12:32 PM
Yes, it can be tested with a good scanner or I think with a OHM meter. Might chek the Rave for testing procedures and numbers.
Old Oct 8, 2009 | 01:22 PM
DDP's Avatar
DDP
why would it idle great until engine warms up then jump rpms?
Old Oct 8, 2009 | 01:36 PM
Good point. Wonder if the fuel pressure regulator is failing causing low fuel pressure at an idle.
Old Oct 8, 2009 | 01:46 PM
DDP's Avatar
DDP
would changing the fuel filter have any effect on pressure ,that is the only thing i have not changed/ or is it the iac valve not holding once its hot ,,,,,,,, man i have confused myself ,,i do appreciate you guys looking in it helps
Old Oct 8, 2009 | 02:43 PM
DDP's Avatar
DDP
Just went 10 miles to lunch stopped and rpm went back to normal? Anyone with an idea?
Old Oct 8, 2009 | 02:53 PM
If the fuel filter hasn't been changed in the last 2 years, it would be a good thing to do.
