-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   idler pulleys (https://landroverforums.com/forum/discovery-ii-18/idler-pulleys-68700/)
redrover75 Aug 15, 2014 09:53 PM
idler pulleys
So a 2003 has 70 and 80mm pulleys plus the tensioner.
Would any pulley of that size work? Amazon sells good year pulleys of that size. Would they work fine?
5kcstq Aug 16, 2014 09:58 AM
Not necessarily. The bearing in the center can be any number of sizes. You'd need to check the bolt hole size of the bearing, as well as the width of the pulley and match that. Any WorldPac dealer can get you the correct pulley including tensioner for about $40 give or take. The smaller pulley is an off the shelf part at Advance Auto for cheap.
redrover75 Aug 17, 2014 11:33 AM
tha
I was wondering about that. It is amazingly inconsistent when I search on the various web site for parts. Is there a way to get those dimensions?
dusty1 Aug 28, 2014 09:46 PM
hey mine just ate itself and wondering if anyone has part # so I can go to lps.
autozone says this 231054 is the number....?????
https://mail.google.com/mail/u/0/?ui...&sz=w1345-h550
edit = that # shows a picture for one that has ridges...the one i need does not
dusty1 Aug 29, 2014 08:24 AM
lps are being dufus and trying to sell me a 100mm pulley
anyone know where to find proper part number?... orielly and azone both have the same 100 no go bs.
redrover75 Aug 29, 2014 08:36 AM
pulleys/ belt
I got mine from amazon but I imagine anyone places could have them.
Dayco 5060865 Serpentine Belt
Order placed on Aug 17, 2014
Dayco 89006 Tensioner & Idler Pulley Dayco 89006 Tensioner & Idler Pulle
Dayco 89054 Belt Tensioner Pulleyy
5kcstq Aug 29, 2014 08:55 AM
Here's what I used and where I purchased them:
wpcG6020135242amr, 70mm WorldPac supplier...Carquest etc. $22.74
PQR101150K, 80mm idler, driver side, Atlantic British. $44.95. Couldn't get local :(
89054, Tensioner pulley, AdvanceAuto, $18.99
Napa sells the bearing for them all as well, however, the main one I needed was the 80mm pulley, and the bearing was more than the whole part from AB.
Hope that helps.
dusty1 Aug 29, 2014 09:14 AM
thank you....
just ordered for pick up from orielly
I crossed pqr500060 to imc #68129005001. I guess i'll figure out if that is correct at noon when they get it in.
dusty1 Aug 29, 2014 02:28 PM
Came as a steel replacement in a gen Lr parts box. It had that pqr.....#.
Fit fine
redrover75 Aug 31, 2014 10:51 AM
Dayco Pulleys
So, the Dayco pulleys I ordered, after sizing from their app are not correct. The 89006 is no where near fitting anything under the hood.
the 89054 for the tensioner is too small by a few millimeters or so. Did not measure it, but it is definitely smaller.
could the tensior be replaced already with one slightly too large and this is the correct one?
Otherwise I am shipping it all back. There is not an Oreilleys anywhere near me which appears to be the place to get these parts. I have an autozone, advanced auto and pepboys close by.
Does anyone have a suggestion or accurate parts list before I overpay at AB?
I am thinking that I will buy an entire tensioner, that pulley is on there pretty good.
thanks in advance,
