Ignition switch push to remove key
Old Nov 27, 2018 | 08:09 PM
Ben Matheson's Avatar
Default Ignition switch push to remove key
When I push the key into the ignition to remove the key it takes enough force I'm concerned I might break a key. Anyone ever modify the ignition to reduce how much inward pressure is needed?
Old Nov 27, 2018 | 08:34 PM
Best4x4's Avatar
Have you lightly lubed it? There is an aftermarket setup that doesn’t require you to push the key in to remove it, but unless they changed it recently it only came with 2 basic non fob keys, and it did not match the drivers door key.
Old Nov 27, 2018 | 08:42 PM
It's been lubed but feels like pure spring tension
Old Nov 27, 2018 | 09:13 PM
longtallsally's Avatar
Minimal tension for me to do it. What I am exceptionally cautious with is turning the key to start it- with all the stories of broken keys and the like. It seems you have to find a “sweet spot” where the keys align with the tumblers.
In your case I’d say something is in the way- I’d disassemble and investigate. Yes, it will suck.
ElVerde
Oct 10, 2019 12:06 PM
ebindustries
Oct 28, 2017 11:57 AM
fishEH
Sep 7, 2016 11:29 AM
wastedincome
Oct 20, 2012 06:02 AM
elpapisf
Apr 18, 2012 06:19 PM
