Inline PCV:
#41
It’s probably clogged or nearly clogged = no flow. What year D2 do you have? 99-02 removal is a breeze! 03-04 wrap the nipple with tape, then gently twist out with some pliers.
#43
Nothing goes back in place of the baffle.
The pvc on the other end of the hose/into upper intake has a one way check valve in it.
Remove the baffle, push the hose on the valve cover, and connect to the thread-in pvc, done.
Myself and several of us have done this per Best4x4's recomendation.
#44
i drilled right through the tube on my '03, because i had the rocker cover off. you need to have some way of connecting the hose to the cover so if you remove the tube entirely, you're going to have to replace it with something. maybe something along the lines of the brass hose spigot that some people used at the intake end when the original plastic part would break? that might thread into the rocker cover and form a good seal.
#45
The 03-04 nipple on the valve cover is pressed in. Wrap it with electrical tape & gently twist it with some pliers. It should come out, then remove the baffle & tap it back into place on the valve cover.
#47
#48
Yeah some are stubborn for sure, you can try soaking it or using a little heat on it, but it is just pressed in. I’ve had some just fall out with the line attached lol, just depends.
#49
that's not the question that was asked. the instruction given for removing the baffle on the '03-'04 models indicated that the entire pipe should be removed ("wrap with tape and twist") but that would leave nothing to attach the hose to. on the earlier years the baffle can be removed from the top without damaging the pipe, but that's not the case on the later models.
