Intake Manifold Gasket Replacement help
I need to replace my Intake Gasket on my 90k mile 2000 Discovery. I need to do this in one weekend so I was wanting to ask someone who has done it what all I will need to order to do this job.
I found this earlier post https://landroverforums.com/forum/sh...=intake+gasket Is this all I will need? Thanks Max |
http://www.landroverresource.com/ Get RAVE, read.
Replace the throttle body heater, they fail as a rule. Check the thin plastic throttle body heater hose, they also fail. Are you replacing spark plugs wires? You may as well if you are taking the IM off. You can get a set of 8mm Kingsbourne wires https://www.kingsbornewires.com/ |
you can do it...
i tore my 04 down to the block in 6 hours with a home depot socket set and a few attachments and it was 96 out side in the sun. You should be able to do in a day...:D
